Ihaveapigeon456
Message 1 of 6
Low download speed but high upload?
I have noticed that my speeds are extremely slow and whenever I do I speed test my upload is normally 5 or even 10 times higher than my download which I thought was weird considering I heard that it should be the other way round. I was wondering if anybody knew a solution. I have a home hub 5 and super fibre unlimited 1. Thanks in advance
5 REPLIES 5
imjolly
Message 2 of 6
Re: Low download speed but high upload?
post stats from hh5  troubleshooting then helpdesk
try btspeedtester with wired conenction and post results  this was giving some odd results in last couple of days   http://www.speedtest.btwholesale.com/
DigitalDave
Message 3 of 6
BT speedtester is broken. Don't waste your time.😥
Ihaveapigeon456
Message 4 of 6
That link that you gave me shows rather 0 download and upload or insanely high speeds (over 4000 mbps). Could you maybe suggest another speed tester that give more accurate results.
imjolly
Message 5 of 6
try this  http://www.speedtest.net/  must be with ethernet   BT will only accept btspeedtester results but at least this will show speeds
need you to post the stats from your hub5
pippincp
Sage
Message 6 of 6
The BTWholesale speedtest does seem to be suffering problems ATM, it started with just chrome and firefox but now appears to be all browsers.
Try one with speedtest.net.
