regtee
Message 1 of 9
Low modem upload sync speed
I am on BT Infinity, and I was having speeds of 17/2 until our cabinet was upgraded 8 months ago and my speeds are now 40/2.
My HomeHub says that the maximum data rate is 9830 / 38622, but the data rate sits at 2.00 Mbps / 39.56 Mbps
The 2mb upload is pretty slow, should I not be getting closer to 10Mbps?
The funny thing is, the DSLChecker seems to be inaccurate.
On DSL Checker I get this:
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperObserved SpeedsVDSLOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)27.117.84.22.415.1Available----
VDSL Range B (Impacted)26.615.54.12.213.1Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 2--1 to 3.5Available--Yes
ADSL MaxUp to 1.5--1 to 2.5Available----
WBC Fixed Rate1 ----Available--Yes
Fixed Rate1 ----Available----
BETUp to 2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date13-12-2018
Here are the logs from my home hub:
Firmware version:
SG4B1000B540
Firmware updated:
15-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
11 Days, 20 Hours 43 Minutes 42 Seconds
Data rate:
Maximum data rate:
9830 / 38622
Noise margin:
16.7 dB / 5.7 dB
Line attenuation:
20.4 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Any help or advice is greatly appreciated.
8 REPLIES 8
imjolly
Message 2 of 9
Re: Low modem upload sync speed
were or are you on the old bt infinity package which was 40/2mb speeds before your cabiniet was 'upgraded'?  if so it looks like the openreach improvements have helped your down speed which is well above estimated but left the up speed at old capped level of 2mb
regtee
Message 3 of 9
I am not sure to be honest, it was a BT Infinity package with speeds upto 40Mb... But I never got anymore than 17 down
imjolly
Message 4 of 9
I think the old package was 40/2mb and looks like your up speed is still capped at old level
when was last time you renewed your BT contract?
regtee
Message 5 of 9
about 15 months ago, its up for renewal in March time
imjolly
Message 6 of 9
I have asked a forum mod to check your account to see if you are capped at 2mb  they will post here and then you complte the form following their link
RobbieMac
Moderator
Moderator
Message 7 of 9
Hi @regtee
Welcome to the Community and thanks for your post!
Sorry that your upload speed is slower than what it should be.  @imjolly is right, it looks like you're on an old profile with a 2Mbps upload speed.  Send us your details, we can check it for you.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
regtee
Message 8 of 9
Thanks for fixing this guys!
I'm getting what I expect for the data rates now:
Data rate:
9.88 Mbps / 41.28 Mbps
Maximum data rate:
9857 / 40860
RobbieMac
Moderator
Moderator
Message 9 of 9
Hi @regtee
Thanks for posting back and I am really pleased that you are seeing a faster upload speed now.
Just to confirm, you were indeed on an old profile where the upload was capped at 2meg.  We placed an order to remove the cap and give you the speed you're getting now.
Enjoy the rest of your weekend Smiley Happy
Cheers,
Robbie
