Message 1 of 8
Low speed on Fibre 1
I have recently upgraded to Fibre 1. This morning I received the email from BT saying "It's time, you can now get going with Fibre", so I restarted my Smart Hub and reset my PC.
However, the BT Wholesale Speedtest gives me a figure of 31.8 Mbps download and 8.91 Mbps upload. This is not a vast difference from my old broadband which usually gave 20 Mbps.
My question is - will the speed gradually increase, since this is a new fibre setup?
I have attached a cropped screenshot of the Speedtest results.2020-04-30.png
7 REPLIES 7
Message 2 of 8
Re: Low speed on Fibre 1
enter your phone number and post results  remember delete number
post hub stats  if hh6 then advanced settings then technical log information
Message 3 of 8
Message 4 of 8
As you can see from your stats, you are syncing at the maximum speed for fibre 1,  55Mbs. Was the speed test done with a wired or wifi connection?
Message 5 of 8
I am using a 72 Mbps wireless adaptor which I was assured by BT would be quite adequate.
Sage
Message 6 of 8
Your speed test result is about right for the adapter you are using. It will not give you your full speed.
Message 7 of 8
Thanks, I should have realised that the wifi adaptor was the weakest link! I fired up my work laptop and the speed test clocked up 41 Mbps - and that was two rooms away! I feel very sheepish now...
What should I be looking for in a new adaptor, for best performance? Or would any 5 GHz one be fine?
Sage
Message 8 of 8
A Mini USB 150Mbps Wireless Adapter would be suitable for you. They are quite cheap on a certain online auction site.
