dogwithabone
Message 1 of 23
Low upload speed, erratic connection
Hi.
Okay so it will be 12 weeks on Tuesday since I placed my home move with BT, it finally went on a week ago after 19 failed orders, the most stressful thing I have ever dealt with.
In short the previous tenants hadn’t cancelled leaving me huge issues.
Anyway I now have infinity. It was getting about 20 down and 1.8 up but Wi-fi connections were all over the place then fine, then not. The ping was 16 upto 1200.
Yesterday I replaced my master socket, instantly got 30 down but only 1.8 up, and still erratic, not all the time but 20% if it.
BT won’t raise a fault until 10 days are up but I think it’s clear something is wrong.
My router currently says 31.8 down and 1.84 up.
My dsl checker used to say 27-40 down and 8ish up, but just checked and all fields are blank?
Any advice please???
22 REPLIES 22
Techwizz
Message 2 of 23
Re: Low upload speed, erratic connection
Please post result from here: http://dslchecker.bt.com
Please post your router stats.
Complete a quiet line test (dial 17070, option 2, from a corded phone). There should be no noise between the announcements.
Is your Hub connected to the test socket? If not, please do so, but remember to post stats before and after.
dogwithabone
Message 3 of 23
 Connection status:
BT Broadband /
BT Infinity /
BT Infinity 3 and 4 :
BT Infinity
 Firmware version:
SG4B1000B540
 Firmware updated:
27-Oct-2018
 Serial number:
+084316+NQ82658454
 Downstream sync speed:
32.71 Mbps
 Upstream sync speed:
1.84 Mbps
 Network uptime:
2 Days, 0 Hours 17 Minutes
 System uptime:
2 Days, 0 Hours 19 Minutes
 BT Wi-fi status:
Not active
dogwithabone
Message 4 of 23
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC Fixed Rate1----Available---- Fixed Rate1----Available----
Other Offerings
Availability Date
  ADSL Multicast------Available----
Premise environment
Status
Bridge TapU      VRI--      NTEFaceplate--      Last Test Date--
dogwithabone
Message 5 of 23
Think I have done that right.
The dsl checker is blank.
I will do the test socket thing as soon as I can. Quiet line test, no noise.
Message 6 of 23
stats are  by going to advanced settings then technical log information
there is no dslchecker info  maybe openreach database not updated yet for your new phone line
Techwizz
Message 7 of 23
Is that the result for your phone number or address? Is the Hub connected to the test socket?
dogwithabone
Message 8 of 23
BT Hub 6A
Serial number:
+084316+NQ82658454
Firmware version:
SG4B1000B540
Firmware updated:
27-Oct-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
2 Days, 0 Hours 23 Minutes 1 Seconds
Data rate:
1.84 Mbps / 32.71 Mbps
Maximum data rate:
2080 / 39451
Noise margin:
7.9 dB / 6.3 dB
Line attenuation:
23.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
12150 MB Uploaded / 40362 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-GC7M
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-GC7M
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A8:9A:93:2B:4F:3F
Software variant:
Boot loader:
9.2.0
dogwithabone
Message 9 of 23
Thats all that is in the dsl checker.
And its for the phone number. Not in test socket, its in the prefiltered faceplate. Brand new.
Techwizz
Message 10 of 23
Line stats look good for the attenuation, except for the upstream, which could indicate a line fault. Can you try connecting via a wired connection and see if the same issue occurs? If not, then it's most likely a wireless issue.
