dogwithabone
Message 11 of 23
Re: Low upload speed, erratic connection
Believe it or not I have nothing with an ethernet port! Even my laptop is wireless.
Techwizz
Message 12 of 23
You're going to need to test with a wired connection, because wireless is susceptible to interference.
Distinguished Guru
Distinguished Guru
Message 13 of 23
You could get one of these for your laptop from a well known auction site.usb.jpg
Message 14 of 23
@Techwizz wrote:
Line stats look good for the attenuation, except for the upstream, which could indicate a line fault. Can you try connecting via a wired connection and see if the same issue occurs? If not, then it's most likely a wireless issue.
The low upstream data rate would indicate it is a broadband fault not a wireless fault.
dogwithabone
Message 15 of 23
Stats through wired ethernet.
Product name:
BT Hub 6A
Serial number:
+084316+NQ82658454
Firmware version:
SG4B1000B540
Firmware updated:
27-Oct-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
2 Days, 1 Hours 0 Minutes 38 Seconds
Data rate:
1.84 Mbps / 32.71 Mbps
Maximum data rate:
2080 / 39306
Noise margin:
7.9 dB / 6.2 dB
Line attenuation:
23.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
12238 MB Uploaded / 40439 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-GC7M
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-GC7M
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A8:9A:93:2B:4F:3F
Software variant:
Boot loader:
9.2.0
Moderator
Moderator
Message 16 of 23
@dogwithabone I'm really sorry about the problem with your upload speed, we'll be happy to take a look at this if you send over your details on the 'click here to contact the mods' link in my forum profile.
You can find the link by clicking on my username.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Techwizz
Message 17 of 23
I know, but even though the upstream rate is low, the connection is stable, so the erratic symptoms are unlikely to be caused by a physical line issue.
dogwithabone
Message 18 of 23
Just sent details Neil, this is however being dealt with by the executive level complaints, they dont think there is a problem either!
Techwizz
Message 19 of 23
What's weird is that the upstream rate is very low, but the connection is stable, so that's why they think there isn't a problem, but there is.
Message 20 of 23
If ELC are dealing, mods won't be able to assist.
