akjmoran
Message 1 of 2
Low upload speeds
Hi, this morning when I woke up my internet was off and wasn't working. I had to restart my router to get it to connect and since then I am literally getting 1.5mbps upload speed when before this morning I was getting around 18. Any ideas?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Low upload speeds
Good morning @akjmoran and thanks for posting.
I'm sorry your upload connection speeds have dropped following our reset. Are you connected via wireless or cable? Are you able to post your hub stats? Can you try running the speedtest on a wired connection and post the results? If you can give us as much information as possible I'm sure we'll be able to help.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
