Message 1 of 42
Lower than guaranteed speed issues
Hi,
My recent new contract from March 14th is now giving me 40.20mb which is below my minimum guaranteed 43mb.
This through a new smarthub 5Smiley Mad
Ive emailed complaints and keep getting missed calls from India and tbh I can see this scenario going around and around.
India left a message to say they can see that I have lower speeds but havent done anything as adventurous as tweaking from there end. Can anyone (Mods) assist in this as I am just getting fed up with these missed calls as they havent called at arranged times!
Thanks.
stuart.
41 REPLIES 41
Message 2 of 42
Re: Lower than guaranteed speed issues
@SRT
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Which BT Home hub do you have?
Message 3 of 42
HH6.pngSmart Hub 6
Thanks.
Message 4 of 42
Your broadband will start by midnight on: 14 Mar 2017
How fast will it be?
The blurb.
We estimate your download speed will be between 49Mb and 55Mb, and your upload speed will be between 9Mb and 10Mb.
The minimum guaranteed speed you can expect from your BT Infinity will be 43Mb.
Message 5 of 42
HH6 Stats. I have had 47mb in past with older hubs.
Message 6 of 42
Pleas can you provide the full stats which include noise margin and max rate.
Use this link http://192.168.1.254/0000012803/gui/#/technicalLog/information
Message 7 of 42
First part.
Message 8 of 42
Second part.
Message 9 of 42
The max data rate is only about 45Mbs, and the noise margin is about right, so you are not going to connect at a higher speed with your current configuration, as something is restricting the available bandwidth.
Which one of these matches your master phone socket?
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 10 of 42
Keith-Thanks for your input.
Phone socket is last one on right. Line seems quiet but will need to get the old wired phone to complete check.
Might it be worth rebooting HH ?
