glenhill68
Expert
Message 11 of 62
Re: MK3 master socket wiring help
Hi. BT engineer fitted the socket awhile back so all should be good. If I remove the faceplate do I connect the router via a filter to the test socket?
Message 12 of 62
yep
glenhill68
Expert
Message 13 of 62
Thanks. I have removed the faceplate on the bottom of the socket. I connected a filter to the rest socket behind the faceplate and then connected the data cable from the hub. The orange light still flashes with the red b.
glenhill68
Expert
Message 14 of 62
Currently a steady orange light and flashing red b.
Message 15 of 62
Do you get dial tone on a phone?
glenhill68
Expert
Message 16 of 62
Yes I do
glenhill68
Expert
Message 17 of 62
But not when using the test socket.
Message 18 of 62
In which case there is something wrong with your wiring.
glenhill68
Expert
Message 19 of 62
Not good then. Was fine until I rebooted the router earlier.
glenhill68
Expert
Message 20 of 62
How do you identify where it is and what can you check? All was good earlier.
