Message 41 of 62
Re: MK3 master socket wiring help
Ok, now we just need to determine which of the 2 possibles is the master socket. If there is no dial tone at the MK3 test socket, check if there is dial tone at the test socket of the other socket you pictured. If so, plug your router in there with a filter and see what happens.  You really need to use a proper tool to insert the wires as using a screwdriver or suchlike can be the cause of wires popping out as the gap has been widened.
You can get a cheap plastic one from Maplin
glenhill68
Expert
Message 42 of 62
I get a dial tone on both sockets, in the dining room and living room. I plugged the router into the dining room socket using a filter and get an orange light with flashing red b. The orange wire seems secured at the minute.
Message 43 of 62
I thought you said yesterday you didn't get dial tone at the test socket of the MK3. The dining room doesn't have a test socket. This is the socket I meant you to check for dial tone at the test socket.
glenhill68
Expert
Message 44 of 62
I am pretty sure I tested this and got a dial tone, will double check.
glenhill68
Expert
Message 45 of 62
Yes, I get a dial tone from the test socket.
Message 46 of 62
Of which one, the MK3 or the other one.
glenhill68
Expert
Message 47 of 62
I get a dial tone from the dining room socket and also from the MK3 test socket in the living room.
Message 48 of 62
Ok, one last test. With the faceplate of the MK3 removed, there should only be dial tone at the test socket and not at any of the other sockets.
glenhill68
Expert
Message 49 of 62
Yes, that is the case.
Message 50 of 62
In that case we have finally managed to ascertain that the fault is external to your property and will require an engineer visit to fix.
