Message 1 of 8
MK3 socket extension
I'd like to install another socket in another room while leaving master where it is.
I understand I can remove the face-plate and cable the A and B broadband extension to another socket..but could someone advise which extension socket/wiring details?
7 REPLIES 7
Message 2 of 8
Re: MK3 socket extension
@sparkymarcopolo1
Who provides your phone and broadband connection, as you cannot do what you are suggesting?
Are you trying to extend just the phone, or just the broadband?
Message 3 of 8
If I can only extend the Broadband that's fine. I just don't know which socket to use on the slave/extension.
Message 4 of 8
Are you using a BT Home hub?
Why not just use an RJ11 extension lead plugged into the broadband socket on the front?
Message 5 of 8
Because I want to run the cable externally and into another wall socket
Message 6 of 8
Then you would need to connect to the data extension terminals, shown in blue on this picture. Only two wires are used.
Message 7 of 8
The socket on the right is what I have (mk3) and the one on the left I have one of those too as it happens (spare room)
Can I use another MK3 (data extension <> data extension) so I can use rj11 case or do I require a different type box?
Message 8 of 8
Easier just to use an RJ11 wall box.
