RobGui
Message 1 of 5
Many IGMP join received for group logs
Hi All
I have been looking for an answer to this but am getting no where fast.
Hopefully one of you kind people may be able to explain.
Below are is my Smart Hub (HH6) details.
Product name:
BT Hub 6A
Serial number:
+084319+-----1514 (edited for security)
Firmware version:
SG4B1000B522
Firmware updated:
07-Feb-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
2 Days, 23 Hours 10 Minutes 20 Seconds
Data rate:
12.90 Mbps / 59.02 Mbps
Maximum data rate:
12740 / 59285
Noise margin:
5.7 dB / 4.9 dB
Line attenuation:
20 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
10193 MB Uploaded / 42675 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
RGNetwork
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-9C3G-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
----------------:AE (edited for security)
Software variant:
Boot loader:
9.2.0
In the "Event log" I am see many "IGMP join received for group"
Here's just a small sample.
23:51:12, 14 Feb.
wl1:IGMP join received for group 224.0.2.3 on interface wl1
23:51:09, 14 Feb.
wl1:IGMP join received for group 239.255.255.253 on interface wl1
23:49:06, 14 Feb.
23:49:03, 14 Feb.
23:47:38, 14 Feb.
DHCP Confirmation of Request
23:47:01, 14 Feb.
23:47:00, 14 Feb.
Can anyone explain whats going on here please.
Everything is working ok so it's not an issue, just a bit confussed to what these messages mean.
Thanks in advance.
4 REPLIES 4
Zombie
Expert
Message 2 of 5
Re: Many IGMP join received for group logs
I believe they are something to do with the multicast that bt uses for bt tv. Even if you don’t use bt tv you will still see it in the logs. I have pages of IGMP myself normally ever 2 minuets it’s doing something. I don’t think it’s anything to worry about.
Maybe come morning when the more knowledgeable members are around they will confirm for you. I recall something not long ago about google chromecast doing something similar if you use that, though I thought google had now fixed that issue.
Distinguished Guru
Distinguished Guru
Message 3 of 5
As @Zombie has stated it is multicast causing this and is perfectly normal.
As shown there are 6 IGMP messages created. Consider them similar to keep alive requests that maintain wireless connection between router and device.
Every hub recieves a create group request which then sends a create group repy.
If BT TV is in use Then a join group request followed by a join group reply would follow.
If no BT TV then leave group request and reply would follow instead.
The final 2 messages are confirm group request followed by confirm group reply.
RobGui
Message 4 of 5
OK I think that makes sense.
I do not have BT TV.
I do see today that 1 of my devices (a pc) has given these lines when connected:
00:39:06, 15 Feb.
00:39:06, 15 Feb.
wl1:IGMP group 239.255.255.253 on interface wl1 started by 192.168.1.35
00:39:06, 15 Feb.
wl1:IGMP group 239.255.255.253 on interface wl1 by 192.168.1.35 requested
As I say, we do not have BT TV.
Do you know of any software or websites that would cause these entries.
Again, this is not an issue. I am just curious and learning from this.
Thanks again for your time and information.
Ibgarrow
Message 5 of 5
Do you have a Chromecast? Suggestion on other posts is that these cause repeated IGMP requests.
