Colan59
Message 1 of 4
Master Socket Query
When I got FTTC  installed a few years ago, before the engineer arrived I ran a new Cat6  cable from my master socket downstairs up a chase into the loft and then down into my box room where my PC  etc. is located.  He used this and moved the master socket there. I have since ran a network to various rooms via RJ45 plate from there.
I now need to move my PC equipment to another room and would like your opinion on best way to deal with the master socket.
Option : 4 would be the easiest, but involves  2 socket joins between master and modem which may drop my speed?
Option : 1 Run a new cable from original Master downstairs up to loft and down to new room and move master to there as originally done. ( Proper thing then would be to get BT Engineer to come and re-terminate at old master and fit new one)
Option 2 : Leave master in box room, run a new cable from back of existing master  straight to a socket in new room and connect Openreach modem to that. ( One socket join)
Option 3 :  Re-route Cat 6 cable in loft to new room and move master socket there. This would involve cutting cable in loft and making a joint in master cable
Option 4 : Use Patch cable from master to RJ45, pick up from RJ 45 already in new room to modem.  Tried to show this with sketch below ( Two socket joins)
Your suggestions would be greatly appreciated.
3 REPLIES 3
Message 2 of 4
Re: Master Socket Query
The cable that needs to be the shortest is from your master socket to modem, so why not leave modem where it is and just use a variant of option4 to connect modem to router. Modem and router have no need to be co-located.
Colan59
Message 3 of 4
Licquorice,  thanks for the prompt reply.
I did not know that had to be the shortest length.  I can do your suggestion which would be the easiest way for me just now.
Is that the same for a modem/router?   If in the future I decided to go for a combined unit  then would I need to move master socket to maintain a short cable length.
Message 4 of 4
In essence, DSL speed is affected by length and quality of cabling whereas in general Ethernet is not.
If you change to a combined unit, again leave the master socket where it is along with the modem/ router and use Ethernet via patch panel to connect PC
