AMann4
Newbie
Message 1 of 3
Master Socket - Smart Hub Query
Hi All,
This may sound stupid to some, but I cannot work out which of these is my master socket in the new place I have moved into...
any insight?
2 REPLIES 2
Message 2 of 3
Re: Master Socket - Smart Hub Query
that is a fibre to premises install you connect your hub via an Ethernet cable between the white Openreach ONT box and the red WAN socket on your hub
Message 3 of 3
As above, you have FTTP so may not have a copper connection with an NTE at all.
