Message 11 of 25
Re: Master Socket Wiring
the speeds quoted by BT are connection speeds not download speeds and as already said you appear to be on infinity 1 and getting max speed 55/10mb  no ISP guarantees download speed
Message 12 of 25
@chopper94 wrote:
I've also attached a screenshot from the bt wholesale speed test, it is identical to the test I did prior to plugging into the mastsocket test slot.
Router stats added to bottom. Showing 55 download speed?
Thanks.
That isn't a speedtest screenshot, it is the DSL checker giving estimated possible speeds.
Newbie
Message 13 of 25
ah hasn't added it all in!
Newbie
Message 14 of 25
Router Stats, DSL Checker.
Further Diagnostics.
Image 18-02-2019 at 16.22.jpgImage 18-02-2019 at 15.56.jpgImage 18-02-2019 at 15.56 2.jpg
Message 15 of 25
Can't see anything wrong there other than the fact that there was a disconnection just minutes before you posted the stats.
Newbie
Message 16 of 25
As you can see below, it refers to the guaranteed minimum speed.
I want to achieve this, my favorite analogy at the minute, you wouldnt buy a crate of apples which said a minimum of 50 apples each month if some months you get 22 and the best you can hope for is 46.
Thats a lot of missing apples over the course of 18 months.
Message 17 of 25
Ok, you've chosen the 55/10 package which your line is syncing at. You would very likely see higher speeds if you were on the 80/20 package (we would need the detailed line stats to confirm this). BT, as an ISP, don't guarantee download speed, they only guarantee line speed.
I totally agree with your analogy, and if it applied to the line speed, then yes you have every right to complain, but like I said, download speed isn't guaranteed, BT will only intervene if it's significantly lower than the line speed on a wired connection (normally caused by congestion).
Sage
Message 18 of 25
Those aren't the router stats either. You can find them at Advanced settings/technical log.
Newbie
Message 19 of 25
Product name:
BT Hub 6A
Serial number:
+084319+NQ73006948
Firmware version:
SG4B1000B540
Firmware updated:
24-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 2 Hours 53 Minutes 23 Seconds
Data rate:
10.00 Mbps / 55.00 Mbps
Maximum data rate:
35462 / 99957
Noise margin:
23.9 dB / 18.9 dB
Line attenuation:
16.8 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
12305 MB Uploaded / 12556 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
A
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-QR2C-5
5 GHz wireless channel:
Smart (Channel 48)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 2
Firewall:
On
MAC address:
B8:D9:4D:58:EB:8F
Software variant:
Boot loader:
7.33.1
Message 20 of 25
@chopper94 wrote:
Which is exactly what you are getting, in fact you are getting more than your guaranteed speed of 50Mbps
