Techwizz
Message 21 of 25
Re: Master Socket Wiring
Yes, nothing wrong with those stats either.
chopper94
Newbie
Message 22 of 25
You guys have highlighted the difference between download speed and line speed.
I have been running the bt wholesale speed test which has come up to 46 from between 10-22. Which is great. I was just expecting that test to come up to that guaranteed minimum of 50.
So where BT has said "We estimate you download speed will be...." That doesn't refer to what I should expect to see in that bt wholesale speed test?
Finding it difficult to seperate these two things in my head!
Distinguished Guru
Distinguished Guru
Message 23 of 25
Connection speed as defined by all ISP's includes overheads. Overheads are the extra information that needs to be transmitted for your connection to work and connect to sites etc.
Speedtests do not show this extra bandwidth used even though the speedtedt site has to make use of it.
Message 24 of 25
It is badly worded, it should state connection speed not download speed. Download speed will always be lower than connection speed due to protocol overheads.
Message 25 of 25
