Message 1 of 10
Master socket wireing/removing
Hello,
I've moved into a house couple of years ago - the set up was inhertited after previous owner.
I'm on 55/10 and was getting around 43/10 for last couple of months.
The previous owner has replaced BT master socket and installed non-bt socket.  I've had a fault with  BT maybe 3 years ago and had BT engineer over. BT man advised that this non-bt master socket should be removed as its not used, there is alos a ringer which takes some line capacity.
Recently I decided two remove the non branded BT socket and short 2 wires toghether as there is no need for 2 sockets.
My phone and router are connected to second socket.
The speed went up to 47/9 however the ping went up to 50ms.
Ive checked the logs couple of days ago and both far end and near end was on interleaving.
Yesterday upload was put to fast connection however download is still on interleaving.
I've done a quiet line test with corder phone and there line appears to be fine - no crackling at least.
I've checked the DSL stats on the router and it appears that there a lot FECS errors - but I've read that it's acceptable.
Could someone look at the stats below and advise if they are acceptable. I understand that higher ping is caused by 986 Interleave.
FECS16022
Actual Rate55000Kbps9995Kbps
Attainable Rate77366Kbps20972Kbps
Path ModeInterleaveFast
Interleave Depth9861
Actual PSD5. 4dB5. 6dB
 Near End                 Far End
TrellisONON
BitswapOFFON
ReTx0 0
SNR Margin3dB13dB
Attenuation18dB20dB
CRC01025
FECS16022s16435s
ES0s838s
SES0s10s
LOSS0s579s
UAS35s19122s
HEC Errors00
RS Corrections00
LOS Failure00
LOF Failure00
LPR Failure00
NCD Failure00
LCD Failure00
NFEC25571
RFEC1616
LYSMB271717901
9 REPLIES 9
Message 2 of 10
Re: Master socket wireing/removing
you have max connection speed for your package 55/10mb  you can't get any faster unless you upgrade
Message 3 of 10
Thanks for coming back to.
Due you think the interleave be likley removed in the connection is stable in next few days.
Sage
Message 4 of 10
If stable for the next couple of weeks.
Message 5 of 10
Should i be woried by FECS error on download. Stats on upload doesnt seem to refresh or may be they are none hence its on gfast
Sage
Message 6 of 10
You aren't on G.Fast. That is a VDSL modem, it won't work with G.Fast.
Message 7 of 10
I think the OP means Fastpath rather than G.Fast.
The FEC errors are nothing to worry about.
Message 8 of 10
Thanks for correcting, you are right
Message 9 of 10
Re: Master socket wireing/removing - interleaving
my connection has been stable for almost 10 days see the stats below
unoftuntely interleaving hasnt been removed
should I be woried about increasing crc errors - it appears that every night couple of crc errors are added to the table
would putting back HH that i have help removing interleaving faster?dsl compare2.jpgdsl compare.jpg
Message 10 of 10
Quick update
Today an interleaving got remove of my line. It was on for 28 days. Hopefully it will stay like that
Kept the router on for most days, however it has been restarted every couple of days  due to different reasons. The router was on for last 5 days. Just couple of crc and es a day.
