Boudges
Message 1 of 3
Max Data Rate
Just a quick one!
On the Hub6 where it says the max connection speed. It was 140000 kbps and now it's 130000 kbps. I know it's irrelevant as it's not even close to my 80mbps speed but does it mean anything?
Cheers
If you liked a post, please click on the 'Ratings star' on the left hand side of the post.
2 REPLIES 2
Message 2 of 3
Re: Max Data Rate
Its simply the maximum potential connection speed for your line, it will vary depending on line conditions.
Your actual connection speed depends on which package you are paying for.
Message 3 of 3
Re: Max Data Rate
you may find the max rate drops even further as more people are added to your cabinet but as long as your conenction stays at 80mb then there is no problem
