spain100
Message 1 of 7
Max available speed
Hi
I had a fault on my line which was fixed by openreach in June but since then the maximum speed I can apparently get seems to have been fixed to 40Mbps.  I am on Superfast Fibre 1 and although my speeds were never more than around 40, before on the BT site I would be told I can get speeds up to 56Mbps, which ties up with what the ADSL wholesale checker says, picture below, and what the openreach engineer said on his visit.  Since then however BT say I can expect speeds of only 39-40Mbps. I wonder whether there is some sort of switch left on/off which now restricts the top speed or is this really the best I can expect from my line?  With the recent price increases I am currently reviewing my options and frankly if thats the best I can get I can get a better deal elsewhere, with guaranteed no proce increases.
Thanks for any help
6 REPLIES 6
Distinguished Guru
Distinguished Guru
Message 2 of 7
Re: Max available speed
The up to 56Mb is merely an estimate. Your hub will tell you what your max attainable speed is for your line.
Post the connection stats from the hub.
HH6 Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
spain100
Message 3 of 7
Thanks for the reply, below is a snapshot of the technical log, assume this is OK?
19:53:31, 10 Aug.
wl0:IGMP group 239.2.0.252 on interface wl0 ended by 192.168.1.211
19:53:26, 10 Aug.
wl0:IGMP join received for group 239.2.0.252 on interface wl0
19:53:26, 10 Aug.
19:53:26, 10 Aug.
wl0:IGMP group 239.2.0.252 on interface wl0 started by 192.168.1.211
19:53:26, 10 Aug.
wl0:IGMP group 239.2.0.252 on interface wl0 by 192.168.1.211 requested
19:53:19, 10 Aug.
wl0:IGMP leave received for group 239.2.0.252 on interface wl0
19:53:19, 10 Aug.
19:53:19, 10 Aug.
19:52:07, 10 Aug.
BR_LAN:The DHCP options that are offered by the device (id:14): DiscoverOptions: 53,61,57,60,12,55 | DiscoverOption55: 1,33,3,6,15,28,51,58,59 | RequestOptions: 53,61,57,60,12,55 | RequestOption55: 1,33,3,6,15,28,51,58,59 | HostName: android-7c219bcaef39c112 | VendorId: dhcpcd-5.5.6
19:52:07, 10 Aug.
:DHCP Confirmation of Request
Message 4 of 7
No, that's the event log, we need the information page.
spain100
Message 5 of 7
Sorry right here you go:
Product name:
BT Hub 6A
Serial number:
+084316+NQ62234615
Firmware version:
SG4B1000B540
Firmware updated:
21-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
8 Days, 20 Hours 50 Minutes 40 Seconds
Data rate:
9.99 Mbps / 41.21 Mbps
Maximum data rate:
13409 / 40895
Noise margin:
7.2 dB / 6 dB
Line attenuation:
20.7 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
12828 MB Uploaded / 109955 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-GCGS
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-GCGS
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:1C:CF:2B
Software variant:
Boot loader:
7.33.1
Message 6 of 7
I'm afraid you are getting about as fast as you are going to get and within the range shown on the checker.
spain100
Message 7 of 7
Ok thanks for your help
