Odai
Message 11 of 24
Re: Max speed estimate of 55mbps - Unlimited Infinity 1 or 2?
Looking through the technical log, I find the following:
Maximum data rate:
20526 / 68647
Noise margin:
14 dB / 10.5 dB
Line attenuation:
20.3 dB
licquorice
Message 12 of 24
Looks like there is scope for higher speed with Infinity2, but do you actually need it? Unless you are streaming multiple 4K channels simultaneously you won't notice the difference.
imjolly
Message 13 of 24
with noise margin at 10.5db certainly scope for faster connection possibly mid 60s
imjolly
Message 14 of 24
@licquorice  you will notice it if you upload a lot of large files
licquorice
Message 15 of 24
True
Odai
Message 16 of 24
Thanks guys. In that case, will certainly look to get in touch with BT to enquire.
Given my usage I think I can benefit.
Might it be worth seeing what happens to those posted stats over the next few days, or are they fairly stable on new connections?
imjolly
Message 17 of 24
with such a high noise margin I think line should be ok
just check for line noise by dialing 17070 option 2  should be quiet and best with corded phone
Odai
Message 18 of 24
Thanks for the tip, will do.
However, that does remind me of something potentially relevant.
We are currently renovating the house and as a result the landline phone is actually disconnected. I therefore don't have anything plugged into the ADSL filter other than the DSL cable for the Hub.
Once we have finished renovating and I've re-connected the phone to the filter, could this potentially affect any aspect of the line stats?
licquorice
Message 19 of 24
No, won't affect stats.
pippincp
Sage
Message 20 of 24
It shouldn't.
