itsjamielike
Message 1 of 7
Maximum Attainable Speed on this line?
Hello,
If anyone is able to understand these stats, could you give an educated guess on what the maximum attainable speed would be. Things have changed slightly since I used ADSL and Line Attenuation was simple to read and work out before I moved to Virgin.
Many Thanks,
Jamie
Broadband LinkDownstreamUpstream
Connection Speed (Kbps)7044220000
Line Attenuation (dB)DS1:7.5    DS2:15.8    DS3:23.7US0:5.1    US1:14.0    US2:19.0
Noise Margin (dB)DS1:6.2    DS2:6.1    DS3:6.1US0:11.5    US1:11.0    US2:11.2
IT Tech for 9 years in the Private and Public Sector, recently giving it up for a totally different career change.
6 REPLIES 6
Message 2 of 7
Re: Maximum Attainable Speed on this line?
No idea. Does your modem not report max attainable speed directly, most do? If not re-connect a Home Hub temporarily.
Message 3 of 7
Enter your phone number and post results remember delete number   http://www.dslchecker.bt.com/adsl/adslchecker.welcome
itsjamielike
Message 4 of 7
The below is from the BT checker, I appriciate I am just out the Clean range and still within the impacted.
I was hoping someone would be able to make a guesstimate as you were able to with Adsl packages with a calculator.
VDSL Range A (Clean)8071.9201966.4Waiting listWaiting list
VDSL Range B (Impacted)8068.5201961.9Waiting listWaiting list
G.fast Range A (Clean)293.8211.747.923.5187AmberAmber
G.fast Range B (Impacted)256.4187.633.916.5172.2AmberAmber
Message 5 of 7
Unfortunately no charts like adsl.  As @licquorice  said if you connect hub then that will show attainable not to say you will ever reach that though
have you tried test socket with filter  to see if that improves connection?
as your noise margin is about normal 6db suggests attainable just above actual
itsjamielike
Message 6 of 7
To keep everyone updated, the day after this post I have been running my line at the below. Posting for anyone in future with fimilar stats curious.
Broadband Link Downstream Upstream
Connection Speed (Kbps) 80000 20000
Line Attenuation (dB) DS1:7.6 DS2:16.0 DS3:24.0 US0:5.1 US1:14.1 US2:19.2
Noise Margin (dB) DS1:6.8 DS2:6.8 DS3:6.6 US0:11.1 US1:10.8 US2:11.0
Message 7 of 7
great  connection just took a bit time to settle
