Message 1 of 4
Maximum data rate
Hello, I was wondering what the "Maximum data rate" means and if its possible to somehow to ring BT and to get that speed? Is the "Maximum data rate" even achievable? I am on FTTC SoGEA pretty close to the cabinet.
3 REPLIES 3
Message 2 of 4
Re: Maximum data rate
you are on FTTC and the max package speed available is 80mb which you have   you cannot get faster with current package
Message 3 of 4
Yeah I understand that, is the limiting to 80Mbps to do with Openreach then? As other countries with VDSL2 can hit 90-100. Do they do this for capacity, stability, or something?
Message 4 of 4
VDSL in this country is rate limited to 20Mbps Upload, 80Mbps Download by Openreach for all suppliers.
