Message 11 of 18
Re: Maximum wait time for DLM to make a change?
@Sinuous wrote:
Hi I just have to ask, I've waited over 100 days for a change but there's been nothing. My connection has been completely stable for 104 days.
Firmware Version:0.6.0 1.8 v0021.0 Build 140925 Rel.32089n
Hardware Version:TD-W9980 v1 00000000
System Up Time:103 day(s) 23:43:17
Are you judging your stable connection by the System Uptime or the router logs? Just that the system uptime on the 9980 is purely the powered up time not line uptime in case you weren't aware.
Message 12 of 18
@licquorice
that could be reason that DLM has not reduced noise margin
Sinuous
Message 13 of 18
Those days ago I had manually switched it off due to a small glitch with the router. That is when the counter started.
Distinguished Guru
Message 14 of 18
The point is that when you switched off/on the modem/router the system rebooted and has been up for 104 days since. However it may have been dropping the broadband connection and re-connecting lots of times during that period.
Is there a connection time listed, or a log that shows entries with time/date for the last connection?
Message 15 of 18
@Sinuous  You need to go to System Tools > System Log to check for DSL events to verify broadband connectivity.
Sinuous
Message 16 of 18
Umpire, the LED lights on my TP-Link are a bit strange. The internet LED light is always shown as off except for a few days affter a reconnection, then it switches itself off. But the internet connection works fine. If I had experienced a disconnection, I would see that light on again.
liquorice I checked the logs, there have been no errors or warnings whatosever.
Sage
Sage
Message 17 of 18
That could be an equipment problem, have you an HH5 to compare stats?
Message 18 of 18
That is definitely wrong, the internet light should be on. I notice you are using old firmware, it might be worth updating to the latest 150507 obtainable here. http://uk.tp-link.com/download/TD-W9980.html#Firmware
