Message 1 of 10
Migration from ADSL to Infinity 1, still on ADSL
Hello,
I've switched my elderley in laws over from Plusnet adsl to BT Infinity 1 and there new speed is exactly the same as itwas on ADSL, despite when we ordered it BT said the estimated download was 32Mb-45Mb and minimum 29Mb.
Here are the Homehub 6 figures:
Data rate:               1.47Mbps / 6.87 Mbps
Maximum data rate: 1465 / 7383
Noise margin:          6.3dB / 7 dB
Line attenuation:      27 dB
VPI/VCI:                  0/38
Latency type:           G_933_2_ANNEX_B
Its a bit of a trek to their house and so I got my Mother in Law to call BT and they said everythings ok and the speed should improve!
It looks like they are still on ADSL can anyone give me any help with what to do next?
Thank you
Gary
9 REPLIES 9
Message 2 of 10
Re: Migration from ADSL to Infinity 1, still on ADSL
Welcome to this user forum.
That modulation G_933_2_Annex_B  is odd, are you sure you have written it down correctly?
In order to find out what services and speed range they should be getting, please enter their phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Message 3 of 10
G.993.2 ANNEX B that is infinity so you are on fibre not adsl
can you try and get connected to test socket witrh a filter and see if that improves the connection speed
Message 4 of 10
Hello Keith,
yes that is correct, I took a screen shot and confirm thats what the home hub is reporting.
Here is the output from the link you just sent:
Exchange Weyhill Cabinet 13
DSL Range A (Clean)
41.7
30
8.2
6.1
27.4
Available
VDSL Range B (Impacted)
32.7
20
7.5
3.9
16.5
Available
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 10.5
8.5 to 12.5
Available
WBC ADSL 2+ Annex M
Up to 10.5
Up to 1
8.5 to 12.5
Available
GAry
Message 5 of 10
@Stressedorson said Latency type:           G_933_2_ANNEX_B
Message 6 of 10
Hello,
thank you for the reply and I'm glad its Infinity, I'll drive over there later and try the test socket. They are using a filter as opposed to a filtered faceplate.
Gary
Message 7 of 10
Probably something wrong with the way they have it wired up, or an issue with their internal wiring.
They can get a free visit to sort this out, once 10 days have elapsed.
See Complaints about slow broadband speed
I see you are going to take a look yourself later, so you may be able to sort it out.
When you go there, try connecting things up as shown on this diagram and see if the connection speed increases.
Infinity - test socket connections
Message 8 of 10
@Keith_Beddoe maybe a just typo?
@Stressedorson  can you check modulation figure
Message 9 of 10
@Keith_BeddoeMany thanks for the useful links I will try those in the 10 day period, I have looked a historical speed tests and pre migration ADSL tests were over 7 Mbps down and about the same up.
@imjollyModulation is G_993_2_ANNEX_B, there is no figure.
Regards
Gary
Message 10 of 10
@Stressedorson  thanks just your initial post was 933 not 993 like I expected - just a typo
