Blinky2134
Message 11 of 25
Re: Mis-sold BT Infinity - dont think I will ever be able to get my guaranteed minimum!
Excellent, thanks Keith. Will that show if my modem is somehow being throttles to a lower speed and that the line conditions do allow for a greater speed? Still just wondering if I'm setup to use the Sky fibre speed and not the BT speed of 52 Mbps
Keith_Beddoe
Message 12 of 25
The home hub will show the actual data rate, and the maximum data rate (just a guide), and the upstream and downstream noise margins.
It will become clearer once you have the informatiion, there are lots of people here who can advise you.
Blinky2134
Message 13 of 25
Cheers, will post tonight
imjolly
Message 14 of 25
@Blinky2134 wrote:
I also tried plugging it into the master socket int he hallway to remove the internal wiring but it made no difference. I really dont want to wait 10 days before then arranging to get an engineer visit to them be told there is nothing that can be done!
 Are you using an extension socket st present?  If so you really need to connect to the test socket which is normally behind the bottom half of the master  that should be your best connection and where any engineer will use
Blinky2134
Message 15 of 25
Good point! I can do that tonight as well
Blinky2134
Message 16 of 25
Product name:
BT Hub 6A
Serial number:
+084316+NQ74258226
Firmware version:
SG4B1000B522
Firmware updated:
30-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 18 Hours 2 Minutes 39 Seconds
Data rate:
5.56 Mbps / 27.33 Mbps
Maximum data rate:
5633 / 27832
Noise margin:
6.2 dB / 6.3 dB
Line attenuation:
26.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
218 MB Uploaded / 2395 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
BTHub6-MPTS
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-MPTS
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:4A:65:29
Software variant:
Boot loader:
9.2.0
imjolly
Message 17 of 25
as uptime is 18hrs I assume these stats are from the extension socket and not the test socket  you need to conenct to test socket with filter and repost stats  at same time check that all your extension sockets whether in use or not do not have a dial tone
Blinky2134
Message 18 of 25
Here it is on the master/test socket and I confirmed the other extensions are now offline
Product name:
BT Hub 6A
Serial number:
+084316+NQ74258226
Firmware version:
SG4B1000B522
Firmware updated:
30-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 2 Minutes 29 Seconds
Data rate:
9.99 Mbps / 30.45 Mbps
Maximum data rate:
11012 / 31076
Noise margin:
6.4 dB / 6.2 dB
Line attenuation:
22.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
0 MB Uploaded / 1 MB Downloaded
Broadband username:
BT Wi-fi:
Not active
BTHub6-MPTS
Smart (Channel 11)
BTHub6-MPTS
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:4A:65:29
Software variant:
Boot loader:
9.2.0
imjolly
Message 19 of 25
as that is from the test socket test socket.jpg thne can see you getting any faster and need engineer visit but you will need to wait the 10 days before openreach will send engineer
this is a help page form @Keith_Beddoe
http://forumhelp.dyndns.info/customer/complaints.html
Blinky2134
Message 20 of 25
That was exactly what I thought!  Its so annoying that you need to wait 10 days as it will no doubt be a few days after that before they can actually attend!  Do all the results look ok though?
