Stuartd
Message 1 of 16
Modem says 67Mbps, Wholesale test says 64Mbps profile?
Hi all,
My modem the Draytek Vigor 130 says my line is connected at 67000Kbps with an attainable rate of 69474904Kbps but according to the BT Wholesale line IP profile is set to 64.85. Does that mean that my line is banded?
15 REPLIES 15
brookheather
Expert
Message 2 of 16
Re: Modem says 67Mbps, Wholesale test says 64Mbps profile?
67000Kbps is 65.43Mbps not 67Mbps so looks fine to me.
licquorice
Message 3 of 16
@Stuartd wrote:
Hi all,
Possibly, as you are syncing at exactly 67M with an attainable of 69M not because of the IP profile which will always be lower than your sync speed due to overheads and is about right for 67M sync.
However, if you can tell the difference between 67M and 69M in the real world you are a better man than me.
Stuartd
Message 4 of 16
I hooked up my Draytek to recheck the settings, look at the attainable compared to line sync;
Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 67000000 bps   US Actual Rate       : 20000000 bps
   DS Attainable Rate      : 87329448 bps   US Attainable Rate   : 22067760 bps
   DS Path Mode            :        Fast    US Path Mode         :        Fast
   DS Interleave Depth     :        1       US Interleave Depth  :        1
   NE Current Attenuation  :       11 dB    Cur SNR Margin       :        6  dB
   DS actual PSD           :     0. 9 dB    US actual PSD        :    12. 6  dB
   NE CRC Count            :        0       FE CRC Count         :    11540
   NE ES Count             :        0       FE  ES Count         :     9502
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        2
   ITU Version[0]          : b5004946       ITU Version[1]       : 544e0000
   VDSL Firmware Version   : 05-07-06-0D-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :       12 dB    Far SNR Margin       :        6  dB
   CO ITU Version[0]       : b5004946       CO ITU Version[1]    : 544ed086
   DSLAM CHIPSET VENDOR    : < IFTN >
imjolly
Message 5 of 16
are you or were yo having problems with connection stability - router/modem dropping connection or manual reset or both?
Stuartd
Message 6 of 16
My line used to be 73Mbps but it has been synced at 67Mbps for months now with no line resets, the uptime on the modem is crazy.
imjolly
Message 7 of 16
@Stuartd wrote:
' the uptime on the modem is crazy.'
obviously the uptime on the modem is improtant as far as internet stability so can you expand on your comment
Stuartd
Message 8 of 16
The modem has two line resets in the last 4 months.
Stuartd
Message 9 of 16
So is it banded?
licquorice
Message 10 of 16
Certainly looks like it. Your attainable is much higher than the figure you quoted in your original post so worth pursuing. You will need an engineer visit to get a DLM reset.
