imjolly
Message 11 of 16
Re: Modem says 67Mbps, Wholesale test says 64Mbps profile?
I find it really unusual that with only 2 resets/drop in connection in 4 months that you are in a banded profile as banding normally result of far more resets in shorter timescale
licquorice
Message 12 of 16
Unfortunately DLM can get stuck and not release banding once line regains stability.
pippincp
Sage
Message 13 of 16
I find it strange that in the first post " line is connected at 67000Kbps" and "attainable rate of 69474904Kbps" from the Draytek suddenly becomes  "67000Kbps" with "87329448 attainable" once the Dratek is "hooked up to check settings".
Deos this mean the OP keeps switching equipment?
DanielS
Moderator
Moderator
Message 14 of 16
Hi @Stuartd,
We can take a look at your profile to see what it's set at. However; are you switching between routers/hubs checking the stats?
DanielS
Stuartd
Message 15 of 16
I am checking the stats by plugging directly into the modem via a laptop, I did reset the modem however.
NeilO
Moderator
Moderator
Message 16 of 16
@Stuartd I'll send you a private message in a moment so you can send over your details and we'll be happy to get this looked into. https://community.bt.com/t5/notes/privatenotespage
