Message 1 of 47
Modem sync speed
My modem BTHub6 shows a sync speed of 35Mb/s.
My package is BT Infinity Up to 52Mb/s.
Speed test results are 31Mb/s (max) down and 9 Mb/s up
My question is:
Should my modem be syncing at a speed much closer to the 52 Mbs quoted given that my sync speed with my previous broadband supplier was 67Mbs, albeit on a different tariff?
46 REPLIES 46
Message 2 of 47
Re: Modem sync speed
the key phrase is 'up to 52mb' - some customers will get that others won't
post stats from your hh6 advanced settings then technical log information
enter your phone number and post results  remember delete number  https://www.btwholesale.com/includes/adsl/main.html
try quiet line test  dial 17070 option 2  should be silent and best with corded phone
Message 3 of 47
Message 4 of 47
Message 5 of 47
Your line is capable of 65M but has been banded by DLM at 35M due to instability. If you maintain a stable connection, DLM will return your speed to the maximum of your package 55M. Do not be tempted to keep resetting the hub as this will make things worse.
Message 6 of 47
How long will the 'return to maximum' take?
Message 7 of 47
Probably weeks rather than days.
Message 8 of 47
I've just done the quiet line test and I can hear very faint rustling. Could this be the cause?
Message 9 of 47
if there is noise on quiet line test and you have also tried from test socket and still there then report a phone fault not broadband  to 151
Message 10 of 47
Thanks to you both for your advice. I may post back here in a few weeks with an update of my speed but I’m not convinced that it will increase before my 18 month contract ends in October.  From reading other threads I get the feeling that ‘banding’ and DLM are synonyms for ‘throttling’.
