Thanks DanielS,
What happens next then? Is an engineer scheduled to visit or am I to wait and see if my connection speed improves over the weekend?
Thanks for your help.
Hi @Rvwill48
@DanielS isn't in the office at the moment. I've passed on your message and he'll be back in touch tomorrow
Cheers,
Robbie
Community Moderator | RobbieMac | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the star next to a reply to say thanks | Help guide to using the community? Click below |
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You |
Hi @Rvwill48,
You don't need to do anything and you don't need to wait in for an engineer. I'm hoping that my change will happen tomorrow evening. If all goes to plan you should notice an improvement over the weekend. I'll be in the office on Monday between 12.30-9pm so I can call you and see if you've noticed an improvement then. Does a particular time suit you on Monday?
DanielS
Community Moderator | DannyS | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the thumbs up next to a reply to say thanks | Help guide to using the community? Click below |
Hi @DanielS,
Thanks for your help. Monday is quite busy for me but I should be at home between 1.30 and 2.30pm and from 7pm on.
Regards,
Richard
Thank you @Rvwill48,
If you aren't free to speak with me on Monday, you can post up here or else send me a private message.
I'll be checking your connection on Monday so I should see if there has been any improvement.
DanielS
Hi @DanielS,
My modem download sync speed is now 55Mbps and my first test result is below. Already a significant improvement on the previous 32Mbps I was getting previously.
Many thanks for your help.
Richard
Hi @DanielS,
Broadband has been working fine until 12.30 today (Sunday). We lost it for a couple of minutes, then it returned for a short while and went completely at 12.45. No connection whatsoever now.
Unable to tell if it’s just me or the whole of Sheffield.
Hi @Rvwill48
Thanks for posting @DanielS is in the office tomorrow I'll ensure he see's these messages on his return.
In the meantime you can check for any issues in your area using this link
Stuart
Community Moderator | StuartH | |
Thanks @StuartH,
Modem appears to have been stuck on solid orange for about 45 mins so decided to switch it off and then on again. It’s now working OK. Do you have any idea what might have caused that?
Richard
Hi @Rvwill48
It sounds like the internet session dropped and rebooting your hub has resynced your connection with the cabinet restoring the session. Unfortunately a number of things could be attributing factors so I can't really offer more than that.
What speed has it reconnected at?
Stuart
