Message 31 of 47
Re: Modem sync speed
55Mbps down, 10Mbps up
Moderator
Moderator
Message 32 of 47
Hi @Rvwill48
Good at least it hasn't affected the speeds.
I've dropped Daniel an email so he can catch up with you tomorrow.
Cheers
Stuart
Distinguished Guru
Message 33 of 47
Good Afternoon @Rvwill48,
I'm happy to see your speeds have improved. I'm sorry about the drop you had. That can happen when the line is recalculating speeds.
I'm going to send you a private message to give you some more information about your speeds Smiley Happy
DanielS
Distinguished Guru
Message 34 of 47
Hey @Rvwill48,
Your order completed yesterday. It may take a few days before you notice a change. I'm in over the weekend. Can you let me know if you notice any changes please?
DanielS
Message 35 of 47
HI Dan,
Modem sync speed is now back up to 55Mbps.  According to the netwrok uptime it appears to have happened at around 5am today (Sunday)
After running a few tests, the maximum download speed Ive achieved is 51.87 which, compared with the 32Mbps I was getting previouly, is a 62.5% increase, brilliant!
Many thanks for your help and for perservering with this.
Kind regards,
Richard
Message 36 of 47
Baah, humbug!
It's already resynced down to 49Mbps!
Richard
Message 37 of 47
Sounds like the banding of 35 Mb was required then, as there's obviously a problem somewhere. DLM will have imposed that banding due to high errors/resyncs, so until the fault is fixed, then you'll be back to square one; 35 Mb.
Can you post the line stats from the Hub again?
Is your line noisy?
Message 38 of 47
Do you mean this...
Message 39 of 47
Dialled 17070 option 2 and could hear some buzzing in the background.
Richard
Message 40 of 47
did you try quiet line test from test socket to eliminate your internal wiring as causing a problem
post hub stats
