Message 41 of 47
Re: Modem sync speed
Did you use a cordless or corded phone? No, the stats from the router.
Message 42 of 47
My master socket is version 5C, Openreach Mk4
I don't have any internal wiring, ie no extension sockets.  Hub6 and phone are plugged into their respective sockets in the master box.  Quiet line test was done with a corded phone.
Are these the stats you're asking for?
Sage
Message 43 of 47
@Rvwill48 wrote:
Dialled 17070 option 2 and could hear some buzzing in the background.
Richard
If you can hear buzzing in the background you need a line enginner to sort it out as it will effect your broadband. Report a line fault on 151. Don't mention broadband.
Message 44 of 47
Stats look ok ish, not sure why the attainable is so high considering the noise margin, though.
Sage
Message 45 of 47
The stats don't look OK. 4.9dB downstream is not a target margin. Line problem needs resolving.
Message 46 of 47
Err, what? Huawei cabinets have 3, 4 and 5 dB target margins.
Sage
Message 47 of 47
Really? Link please.
