apps16
Message 1 of 2
More Buffering
I switched to Infinity 2 about 4/5 weeks ago.  Not happy with the performance at all.  Speedtest.net appears to show decent enough speeds but all devices that I use have the same buffering and what seems to be instability issues.  According to the checks there isnt an issue, however every device that I have ever had connected to the hub performs rather badly in terms of internet connection.  I am now also tied in to a lengthy and expensive contract with no noticable improvements to my broadband from my previous provider of a standard connection.
X Box one lags and takes ages to load on line content (Wired connection).
4 different I phones and a number of diffent I pads experience similar problems over the wireless network.
I have also tried 3 different PC's including a fresh install which have all also had buffering issues taking ages to load content.
I know this is all very vague and with limmitted detail, however the bottom line is that my connection is absolutely no better with infinity 2 than it was with standard Sky broadband which is really bugging me as I am now paying double the price for it....
If there is any other checks that can be done to help identify any possible technical problem I may be having then I would be grateful for suggestions.
1 REPLY 1
Distinguished Guru
Message 2 of 2
More Buffering
Why didn't you stay with Sky for fibre?
If not, I'll try again 🙂
