Message 1 of 11
Moving home and fibre not available
I am moving home soon and fibre is not available at my new address. What are my options (in contract to November 2023) as a 16mb ADSL connection will not suffice for our requirements (working from home)?
10 REPLIES 10
Message 2 of 11
Re: Moving home and fibre not available
is Fibre not available because none in your area or that your cabinet is full and there is a waiting list?  as you are in contract BT will supply your broadband as part of T&C with whatever connection is available - adsl
enter new address and post results  remember delete address
Message 3 of 11
If you are in contract, and your provider can give you service , even if it’s not as fast as you would like, because it’s your choice to move , its you breaking the terms of the contract , you can either take the slower service, or pay the early termination charges…when you signed up until 2023 , you effectively agreed to be a customer until then, you can still be a customer if you wanted, if you chose not to be, then ETC’s don’t seem unreasonable
Message 4 of 11
Thanks for the reply @imjolly , this is what is showing via the link (note I have replaced my new address with 'XX'):
Address XX, on Exchange XX is served by Cabinet 11
ADSL Products
Downstream Line Rate (Mbps)
Upstream Line Rate (Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+
Up to 16
8 to 19.5
Available
WBC ADSL2+ Annex M
Up to 16
Up to 1.5
8 to 19.5
Available
ADSL Max
Up to 7.5
7 to 8
Available
WBC Fixed Rate
Available
Fixed Rate
Available
Other Offerings
Availability Date
ADSL Multicast
Available
Exchange Product Restrictions
Status
FTTP Priority Exchange
N
WLR Withdrawal
N
SOADSL Restriction
Y
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Oct 2013. The Formal Retirement date for IPstream is from 30 Jun 2014.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Mildenhall exchange:Only single order products are available and ADSL and ADSL2+ products are not shown as available.However for premises that can only be served by SOADSL, BT will continue to accept ADSL and ADSL2+ orders until SOADSL is available.
Thank you for your interest
Message 5 of 11
You need to show the exchange and cabinet number, otherwise advice cannot be given.
Message 6 of 11
which exchange?
Message 7 of 11
Apologies: STANSTEAD ABBOTTS is served by Cabinet 11
Message 8 of 11
Cabinet P11   Openreach fibre not available            SG12 8XH
as you can see there is no fibre cabinet yet so adsl best you can get
Message 9 of 11
Only ADSL https://www.telecom-tariffs.co.uk/codelook.htm?xid=1033133&postcodeloc=14658&cabinet=P11
Unless you are using high bandwidth applications, ADSL should be fine.
Message 10 of 11
Thank you @imjolly @Keith_Beddoe , appreciate your fast responses this morning
