wjfox2019
Member
Message 1 of 5
Multiple, brief disconnections every day
Hi there,
About six weeks ago, I started getting brief disconnections on my line each day. My Internet would go down for maybe 1 or 2 minutes each time, before reconnecting. This happened at random times, and with varying frequency, but was typically about two or three times each day – with occasional days when I didn't have any disconnects.
Prior to this, I never had any problems on my line at this address.
I phoned BT who did line tests, but nothing was found. I had engineers round here on three occasions, who checked both indoors and the cabinet on the street outside, but didn't find any problems. I was sent a new hub (same model as before, BT Smart Hub – Type A) , and I even bought a new computer, but still the problems have continued exactly as before. I'm using a "Master Socket Type 5C – Open Reach MK4", a wired connection to my desktop PC.
More recently, the frequency of disconnects has begun to increase. Yesterday I had 10 disconnects, and already today by mid-afternoon I've had seven. This has become an extremely annoying problem now, and I would really appreciate some help in resolving the matter.
The only slight clue, is that these disconnections happen more often when I start watching a YouTube video, especially one that's in 1080p HD. Not always, but for a significant number of the disconnects.
Below is an example of an error log from today.
12:24:50, 03 Nov.
wl0.2:WiFi security settings have been successfully saved
12:24:50, 03 Nov.
wl0.1:WiFi security settings have been successfully saved
12:24:50, 03 Nov.
wl1.1:WiFi security settings have been successfully saved
12:24:48, 03 Nov.
:WAN DHCPv6 Client Prefix : 2a00:23c5:3f07:c400::/56 (valid time = 315360000 / preferred time = 315360000)
12:24:47, 03 Nov.
ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
12:24:47, 03 Nov.
ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
12:24:43, 03 Nov.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
12:24:42, 03 Nov.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
12:24:42, 03 Nov.
ppp1:TR69 receiving InformResponse message
12:24:42, 03 Nov.
ppp1:TR69 event found : 4 VALUE CHANGE
12:24:41, 03 Nov.
ppp1:TR69 sending Inform message
12:24:40, 03 Nov.
12:24:39, 03 Nov.
12:24:39, 03 Nov.
ppp1:TR69 creating new session with ACS
12:24:38, 03 Nov.
12:24:36, 03 Nov.
BR_LAN:LAN Router Advertisement Setting Updated : M_flag = 0, O_flag = 1
12:24:36, 03 Nov.
BR_LAN:The LAN DHCPv6 Server is active
12:24:36, 03 Nov.
BR_LAN:The LAN DHCPv6 Server is inactive
12:24:36, 03 Nov.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
12:24:36, 03 Nov.
BR_LAN: Allocated prefix = 2a00:23c5:3f07:c400::/64 (valid time = 2026291200 / preferred time = 2026291200)
12:24:36, 03 Nov.
BR_LAN: Allocated address = 2a00:23c5:3f07:c400:8220:daff:fefd:b81 (valid time = 2026291200 / preferred time = 2026291200)
12:24:36, 03 Nov.
12:24:36, 03 Nov.
ppp1: Allocated prefix = 2a00:23c5:3f07:c401::/64 (valid time = 2026291200 / preferred time = 2026291200)
12:24:36, 03 Nov.
ppp1: Allocated prefix = 2a00:23c5:3f07:c400::/56 (valid time = 2026291200 / preferred time = 2026291200)
12:24:36, 03 Nov.
ppp1: Allocated address = 2a00:23c5:3f07:c401:8220:daff:fefd:b7f (valid time = 2026291200 / preferred time = 2026291200)
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:36, 03 Nov.
12:24:35, 03 Nov.
ppp1:WAN DHCPv6 Mode : Statefull
12:24:35, 03 Nov.
12:24:35, 03 Nov.
12:24:35, 03 Nov.
12:24:35, 03 Nov.
12:24:35, 03 Nov.
12:24:34, 03 Nov.
12:24:34, 03 Nov.
ppp1:WAN Router Discovery Setting Updated : M_flag = 1, O_flag = 0
12:24:34, 03 Nov.
12:24:34, 03 Nov.
12:24:34, 03 Nov.
12:24:34, 03 Nov.
BR_LAN: Allocated prefix = 2a00:23c5:3f07:c400::/64 (valid time = 240000000 / preferred time = 0)
12:24:33, 03 Nov.
ppp1: Allocated prefix = 2a00:23c5:3f07:c401::/64 (valid time = 240000000 / preferred time = 0)
12:24:33, 03 Nov.
12:24:33, 03 Nov.
12:24:33, 03 Nov.
12:24:32, 03 Nov.
:WAN: SENSING AUTO VDSL
12:24:32, 03 Nov.
ppp1:New DYN ROUTE is added [81.139.57.100/32 gw 172.16.11.165]
12:24:32, 03 Nov.
ppp1:New DYN ROUTE is added [81.139.56.100/32 gw 172.16.11.165]
12:24:32, 03 Nov.
12:24:32, 03 Nov.
12:24:31, 03 Nov.
12:24:31, 03 Nov.
12:24:31, 03 Nov.
12:24:31, 03 Nov.
12:24:31, 03 Nov.
12:24:31, 03 Nov.
ppp1: Allocated prefix = 2a00:23c5:3f07:c400::/56 (valid time = 240000000 / preferred time = 0)
12:24:31, 03 Nov.
12:24:31, 03 Nov.
12:24:31, 03 Nov.
12:24:31, 03 Nov.
12:24:31, 03 Nov.
ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
12:24:30, 03 Nov.
12:24:30, 03 Nov.
12:24:30, 03 Nov.
12:24:30, 03 Nov.
12:24:30, 03 Nov.
ppp1:PPP: PPP INFO
12:24:29, 03 Nov.
ppp:PPP: IPCP_NAK
12:24:29, 03 Nov.
ppp:PPP: CHAP_SUCCESS
12:24:29, 03 Nov.
ppp:PPP: CHAP_RESPONSE
12:24:29, 03 Nov.
ppp:PPP: LCP_GOOD_ACK
12:24:29, 03 Nov.
ppp:PPP: LCP_REQUEST
12:24:29, 03 Nov.
:PPPoE error: timeout
12:24:13, 03 Nov.
:HTTP UserAdmin login from 192.168.1.68 successfully
12:24:13, 03 Nov.
12:24:05, 03 Nov.
12:24:01, 03 Nov.
12:23:56, 03 Nov.
ptm0.101:VLAN VLAN_DATA connected
12:23:56, 03 Nov.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
12:23:56, 03 Nov.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
12:23:56, 03 Nov.
dsl:VDSL link Up: Down Rate=51145Kbps, Up Rate=14998Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
12:23:52, 03 Nov.
:HTTP UserBasic login from 192.168.1.68 successfully
12:23:34, 03 Nov.
:VLAN VLAN_DATA disconnected
12:23:33, 03 Nov.
ppp1:The DYN ROUTE [81.139.57.100/32 gw 172.16.11.165] is deleted
12:23:33, 03 Nov.
ppp1:The DYN ROUTE [81.139.56.100/32 gw 172.16.11.165] is deleted
12:23:33, 03 Nov.
12:23:33, 03 Nov.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
12:23:32, 03 Nov.
ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
12:23:32, 03 Nov.
12:23:31, 03 Nov.
12:23:31, 03 Nov.
12:23:31, 03 Nov.
12:23:31, 03 Nov.
12:23:31, 03 Nov.
12:23:31, 03 Nov.
12:23:31, 03 Nov.
12:23:31, 03 Nov.
BR_LAN: Revoked prefix = 2a00:23c5:3f07:c400::/64 (valid time = 2026291200 / preferred time = 2026291200)
12:23:31, 03 Nov.
ppp1: Revoked prefix = 2a00:23c5:3f07:c401::/64 (valid time = 2026291200 / preferred time = 2026291200)
12:23:31, 03 Nov.
ppp1: Revoked prefix = 2a00:23c5:3f07:c400::/56 (valid time = 2026291200 / preferred time = 2026291200)
12:23:30, 03 Nov.
dsl:VDSL Link Down: duration was 1400 seconds
12:11:53, 03 Nov.
: HTTP UserAdmin timeout from 192.168.1.68
12:01:06, 03 Nov.
4 REPLIES 4
Message 2 of 5
Re: Multiple, brief disconnections every day
@wjfox2019
You are seeing losses of the DSL connection.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
wjfox2019
Member
Message 3 of 5
I performed a quiet line test.
The line had a very faint crackling. On a scale of 1 to 10, maybe only a 2.
I then switched off the hub, and turned it on again, while repeating the test. The hub light began to flash red, as it normally does before turning blue. During this time, I heard a very slight increase in the crackling – maybe a 3 out of 10.
Overall though it was pretty faint. Not sure what you can deduce from that.
Could these disconnections perhaps be electrical-related? My landlord recently had an electrician in the neighbouring property which is connected to mine.
Message 4 of 5
You line should be silent and any noise is a problem for your broadband. Have you tried using the test socket with a filter to eliminate any internal wiring causing the interference. If noise persists then report phone fault to 151
Message 5 of 5
The crackling you can hear, is only being generated because of a line fault, or something wrong with your internal wiring. You should not be able to hear anything.
