mushka
Message 1 of 7
My IP Profile has dropped
my speed estimate has gone from 79dl to 72dl and now it is 56dl & 13up,, is this due to cross-talk,
6 REPLIES 6
Message 2 of 7
Re: After 4 years my IP Profile has dropped
Most likely.
Message 3 of 7
post the stats from your hub
Moderator
Moderator
Message 4 of 7
Re: My IP Profile has dropped
Hi @mushka I've moved you post to create your own thread. If you post your stats the community will be happy to provide assistance.
cheers
John
mushka
Message 5 of 7
its the bt wholesale checker estimate that has reduced, from 79 to 72  and recently gone to 56dl, all i was asking is it crosstalk, ive had fibre since november 2011 and my dl speed went from 69-71 to 56 in feb 2016 and after checking bt wholesale checker the max estimate has reduced.. thanks michael
Message 6 of 7
The request for stats was to see if your attainable had also dropped or is it just your connection speed
mushka
Message 7 of 7
cannot give stats its a hub 3
