emmawatson
Newbie
Message 1 of 2
My broadband connection is dropping regularly.
hi
I am using BT Broadband. My connection is dropping regularly and I have no knowledge regarding that
If you have any answer then kindly reply me back.
Tags (1)
1 REPLY 1
Distinguished Guru
Message 2 of 2
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
Lines 1-13 will be enough
If not, I'll try again 🙂
