Message 21 of 49
Re: My house is not listed
If a moderator can help they will contact you via this post.
Mark412
Message 22 of 49
Thank you for all your help, i wait for a MOD to get in touch
Distinguished Guru
Distinguished Guru
Message 23 of 49
It's obviously a database error as you appear in the post office postcode checker.
I'm sure a mod will pick this up for you.
Moderator-Retired
Message 24 of 49
Hi Mark,
We should be able to get to the bottom of this for you. Fill out our contact form (the link to which you can find in my profile under "about me") with as much detail as you can and we'll see what can be done.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Mark412
Message 25 of 49
Thank you i have filled the Enquiry form out.
Mark412
Message 26 of 49
Can someone please tell me how this is progressing, i know you are busy but its been over 10 days now.
I filled out the contact form to DeanM and not had a reply or anything.
Thank you
Distinguished Guru
Distinguished Guru
Message 27 of 49
Did you actually go to DeanM's profile to get the link for the form or did you just use the generic one?
Please let us know ASAP.
Mark412
Message 28 of 49
It was the link from Deans profile
Distinguished Guru
Distinguished Guru
Message 29 of 49
I'll flag it for you but it is the weekend and you may not be contacted until Mon or Tue.
I'll make sure it is taken up for you.
Mark412
Message 30 of 49
Thank you for the reply
