Message 11 of 31
Re: MyBT app speed test not working after upgrade
It sounds like the team weren't very clear on what the next steps would be @Quesada
I'd recommend getting back in touch to raise a complaint so this can be looked into.
Lesley
Message 12 of 31
I asked if the IT team who would be informed about the errors encountered in the mybt app could update me on progress. The bt rep I spoke to suggested that might be tricky.
I don’t remember being told that a ticket was being raised, nor was I given any sort of incident number.
Message 13 of 31
Thanks for explaining @jmwww1.
There would usually be some sort of ticket or incident number even if it was part of a wider problem or just an individual account problem.
If you've not heard anything in the coming days, it may be worth speaking to the team again so they can check the account and make sure it has been raised correctly.
Michael
Message 14 of 31
To me, this seems more like a problem with the hub's firmware or software compatibility after the speed drop. Alternatively, try a full reboot of the hub and make sure the software version is the latest.
Message 15 of 31
My hub has been rebooted (at least twice!) and fibre to premises modem also rebooted.
mybt app is up to date.
not sure how hub’s firmware and/or software should be verified nor updated if it is out of date. I also find it odd that BT would allow their app to become out of kilter with hub s/w or f/w without informing customers how to remedy the situation???
This is not the first time the test my speed facility has mysteriously broken… there are other threads on this community forum which document past failures.
Message 16 of 31
You have FTTP, why do you need to run speed tests?  Fibre, unlike copper, doesn't degrade causing a low speed, it either works or it doesn't.
Message 17 of 31
With respect, in my experience degraded performance is not particularly uncommon.
Message 18 of 31
If you are that concerned about your speed why don't you just use the speed tester that Openreach engineers have been told to use which is Fast.com.
If it is not particularly uncommon for your FTTP to have "degraded" performance have you reported a fault?
Message 19 of 31
Fast.com is super for measuring combined speed to a device. It cannot measure speed to the hub… the component which is allegedly guaranteed as part of my contract with my provider.
Message 20 of 31
I have reported the faulty test my speed app
