MaximusPrime
Message 1 of 103
Need cables replaced
Hi,
my BT Faster Broadband is cutting out when there is cold weather
3 Engineers have investigated the problem, still failing
I believe the problem is becaue of low quality old cables to my house
How can I get Openreach to replace these?
102 REPLIES 102
Message 2 of 103
Re: Need cables replaced
You can't. Only Openreach engineers can decided if they need replacing and as you have already had three engineer visits and none of them have said that needs to be done it looks like they are happy that it is not the cause of your problem.
MaximusPrime
Message 3 of 103
When you say happy you mean they are happy to leave me with broken cables?
Message 4 of 103
as long as your phone works ok then yes probably
MaximusPrime
Message 5 of 103
If my broadband doesn't work correctly they must have a duty to fix it?
Message 6 of 103
As imjolly has said plus how do you now they are broken when the engineers don't?
Message 7 of 103
There is only an obligation to provide a working telephone service.
How do you know the cables is broken? If it was indeed broken, you'd have no service at all.
Message 8 of 103
there is no requirement to provide broadband and at worst openreach just refuse to supply your line with broadband - so you cannot demand to get line replaced
as GG said 3 engineeers have not said that is the cause of any problems
MaximusPrime
Message 9 of 103
I know something is broken because the 3 engineers all found errors on my line
The problem is not in my house
The problem is not the exchange nor the cabinet
That means the problem is in the 2.8km of cable to my house from the cabinet
MaximusPrime
Message 10 of 103
34+ year old cable
