Mattlisa81
Message 11 of 13
Re: DLM Reset on my line
Gonna buy a 3rd one soon
Mattlisa81
Message 12 of 13
Ment to say 3rd party one
imjolly
Message 13 of 13
@Mattlisa81 wrote:
Every bt hub I've used does it m8 u find it's a big problem I have bt hub 4 5 and smart hub 1 and smart hub 2 sitting in my draw all do same resets same time every few nights
I have used the HH4/5 SH6 and current SH6(2) and have never had the problem of the hub resetting/dropping connection every few days  I did have the '14 days' reset problem which has now stopped and get 50 days + stable conenction  I suggest you have a conenction problem if you are dropping connection every couple of days
look forward to your DLM update
