H18WKD
Message 11 of 19
Re: Neighbours Have FTTP I Don't
Thank you for the reply, What would you advise i do as clearly there is FTTP in my street.
Starwire
Recognised Expert
Message 12 of 19
Best advice I can give is to fill out the form.
https://www.openreach.com/fibre-broadband-availability-customer
H18WKD
Message 13 of 19
Thank you much appreciated.
H18WKD
Message 14 of 19
Update:
This morning i received an email  stating they have looked into the issue and i can now order FTTP 🙂
BT BROADBAND AVAILABILITY CHECKER
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability DateFTTP Install Process
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)ADSL Availability DateWBC SOADSL Availability DateLeft in JumperObserved SpeedsVDSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean)22.113.12.30.811.4AvailableAvailable--
VDSL Range B (Impacted)22.112.32.30.89AvailableAvailable--
WBC FTTPUpto 1000Upto 220--AvailableKCI2 Assure--
WBC ADSL 2+Up to 6--5 to 7AvailableAvailable--
ADSL MaxUp to 1--1 to 3AvailableAvailable--
WBC Fixed Rate1----AvailableAvailable--
Fixed Rate1----Available----
Max Observed Downstream Speed (Mbps)12.52
Max Upstream Observed Speed (Mbps)2.2
Observed Date2020-02-26
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapY
VRI--
NTEFaceplate--
Last Test Date04-03-2020
pippincp
Message 15 of 19
Good result.
plsHelp
Message 16 of 19
Hi,
I have the same issue. Our adjacent neighbor has the FTTP connection and we don't.
May I know how did you manage to convince them?
Thanks.
H18WKD
Message 17 of 19
Hi. It took sometime but basically you need to contact your supplier i.e BT and ask them to submit an ORDI
You may need to ring back a few times untill you get through to someone who knows what an ORDI is. I think I called and spoke to around 15 operators who didn't have a clue. Then one lad goes yep I know what that is and submitted it.
Once this has been submitted you should then be able to place an order for full fibre a week or so after.
plsHelp
Message 18 of 19
Wow! Lucky you.
I wish I can to talk to the same operator.
Thanks!
H18WKD
Message 19 of 19
I know it's very frustrating having to explain the story time and time again  All I can say is keep trying.
Hope you get it resolved soon.
