TimCurtis
Recognised Expert
Message 11 of 18
Re: Netgear Nighthawk X8 D5800 will not connect to BT infinity FTTC
@protodoc wrote:
Yes, tried it last night and no success, I also checked that this router supports IPV6 and apparently it does.
Had read that Netgear won't & have no intention of supporting BT's implementation of IPv6 , something about the prefix length I believe. I can't add more as I've no idea about this.
Liam_
Expert
Message 12 of 18
@protodoc
Hope this isn't to much bad news, below is a quote from Netgear to their forum members.
Re: IPV6 with BT Infinity - NETGEAR Communities
To quote:
    BT Infinity ISP uses IPv6-PD IPv6 configuration our devices do not support IPv6-PD configuration and we do not have any plans to support this on D6400,D7000, D7800 or D8500 in future.
protodoc
Message 13 of 18
Thanks Webby,
I am going to try to update the Netgear Firmware tonight and if still struggling will take screenshots,
Heres hoping...
protodoc
Message 14 of 18
Yes, I reads something aboput that but have also read reviews of the D5800 where users had no problems setting up the Router/Modem with BT infinity 1 and 2
Liam_
Expert
Message 15 of 18
Theoretically any VDSL modem should work with Infinity, providing you have the correct settings for the connection.
PPPoE and check if the VLAN ID is set to 101
You have the username and password set already.
The only snag being IPv6 won't work properly, might be usable if you have a tunnel service set up but it's still not native IPv6.  Though that should not hinder getting a connection.
protodoc
Message 16 of 18
Gentleman,
I am delighted to report I cracked it!
Up and running  and Soooooo fast :0)
All it needed was a factory reset then set up easily
What a relief.
I can therefore confirm to other Netgear users, the D5800 definitely does work with BT infinity
Thanks you so much for your support,
Mark
Message 17 of 18
Smiley HappySmiley Happy
Anology
Message 18 of 18
So  Mr Bassetts - does it connect or not?
The full title and model capabilities are listed as:
NETGEAR D8500-100EUS Nighthawk X8 AC5300 Tri-Band Quad Stream Wi-Fi VDSL/ADSL Modem Router
Acceptable Phone Line Connections -
BT Infinity
You View
Talk Talk
EE
Plusnet Fibre
Amazon Echo Enabled
This from the manufacturers PDF spec on the integrated modem:
Built-in Modem—Compatible with:
VDSL
VDSL
VDSL2
ADSL
ADSL2
ADSL2+
Todays font color scheme is proudly brought to you by Allsorts
Chew On Em Before They Chew You!
