grahamm1
Message 1 of 6
Network uptime vs System uptime
Can someone clarify what this means?
I'm having occasional loss of broadband, so keeping an eye on the stats on the smarthub.
My Smarthub Manager reports:
Network uptime: 0 Days, 14 Hours 9 Minutes
System uptime: 1 Days, 3 Hours 56 Minutes
Usually when my hub reboots itself (which it does occasionally) the network uptime is the same as System uptime.
Why would it be different?
5 REPLIES 5
licquorice
Message 2 of 6
Re: Network uptime vs System uptime
Network uptime is exactly that, the time since a line or network disconnection.
System uptime is time since hub last rebooted.
A reboot will reset both counters but a line disconnection will only reset the Network uptime counter.
grahamm1
Message 3 of 6
Interesting.... I wonder what caused a line disconnection in the early hours?
We've just had the cable from the pole to the property replaced, together with a new socket (hence the reason I'm constantly checking the stats).
licquorice
Message 4 of 6
Possibly DLM caused the disconnection.
grahamm1
Message 5 of 6
Yes, that would make sense, I guess.
pippincp
Message 6 of 6
DLM action normally (though not always) takes place between 03.00-05.00 as this is considered the least likely time the connection will be in use.
