CJT80
Recognised Expert
Message 21 of 26
Re: New Build BT Fibre woes
@c4rm0wrote:
perfect ill get it ordered as soon as they open at 9am. The BT infinity postcode checker on there site is still saying ADSL but guess its the BT wholesale checker that is more accurate. Any idea of lead time from ordering to go live ? i work from home and 3G/4G signal is poor so hoping it is pretty quick
@c4rm0
Up to two weeks usually I believe.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
pippincp
Sage
Message 22 of 26
Using the postcode checker is unreliable. A check using your phone number will tell you exactly what you can get and estimated speed range.
ojobson
Message 23 of 26
Agree post code checker is not accurate and telephone number check is usually most accurate when it works (only seems to work for bt customers in my experience), however the address checker (where you select your listed property) has, for me, always given the same results or been more useful than the tel’ no. check.
___________________________________
My Blog: oliverjobson.co.uk | My FTTP install experience | Why can't I order Fibre broadband?
imjolly
Message 24 of 26
I thought you now have a BT phone connection and number  probably need to check dslchecker and when show available for your number then you can order
c4rm0
Message 25 of 26
All good i gave them my new BT phone number and ordered superfast fibre 2 unlimited as the check came back all good with a estimate of 70-80Mbps it gets put in on July 31st
ojobson
Message 26 of 26
Wooooo!
Super - that’s pretty quick too.
