@c4rm0wrote:
perfect ill get it ordered as soon as they open at 9am. The BT infinity postcode checker on there site is still saying ADSL but guess its the BT wholesale checker that is more accurate. Any idea of lead time from ordering to go live ? i work from home and 3G/4G signal is poor so hoping it is pretty quick
Up to two weeks usually I believe.
Using the postcode checker is unreliable. A check using your phone number will tell you exactly what you can get and estimated speed range.
I thought you now have a BT phone connection and number probably need to check dslchecker and when show available for your number then you can order
