Steve-78
Message 21 of 31
Re: New FTTP Install
Seeing as the callback from customer services never happened I phoned the FTTP team directly instead, they spoke with Openreach while I was on the phone & on the basis of what’s been said this evening Openreach are saying there’s no reason why the install can’t take place as I can definitely get fibre. Only possible problem they saw was that the connection point is in a neighbours garden but other than that they’ve no idea why the engineer said it wasn’t possible. Now awaiting a further update on Thursday to see what’s what.
Sage
Message 22 of 31
The engineers report should be in tonight or tomorrow morning and they'll know more.
tarbat
Message 23 of 31
@Steve-78wrote:
What’s an ONT??
Three connections:
  • Power, from the supplied mains adaptor
  • Port 1 - Ethernet cable to BT Smart Hub
  • Optical - the fibre from outside the house
jonstatt
Message 24 of 31
The new Nokia ONT is way smaller than that and has no Telephone port.
tarbat
Message 25 of 31
 I guess that will depend on whether the exchange OLT is Nokia or Huawei. @jonstatt, what size is the new Nokia ONT?
Sage
Message 26 of 31
Wouldn't matter what kit the exchange is running.
jonstatt
Message 27 of 31
I will have to measure it but this is what it looks like.
Steve-78
Message 28 of 31
@tarbat Thanks for that but it looks like it could be a while before I see that fitted in my house!
Openreach have advised BT that the current route to my house isn’t suitable for a fibre cable, when pressed further on exactly what that meant they said there’s no available fibre ports on the pole & Openreach are going to look into what can be done to get me FTTP with an update due on Tuesday.
I thought leaving Sky & their available/not available/available/no capacity etc Ultrafast mess behind would rid me of the headache that caused me, seems it’s now following me over to BT!
tarbat
Message 29 of 31
As you’ve found, both BT and Sky are equally dependent on Openreach 😞
Steve-78
Message 30 of 31
So after almost a month of repeated phone calls & going back & forth between BT & Openreach my FTTP install is no more.
Openreach have now officially killed off any hope of getting it saying that it’s not available in my postcode/to my property.
Tried to point out that houses across the road from me (odd numbers) are showing as having availability for FTTP but they still insist it’s not available in my area despite previous emails & leaflets through the door saying otherwise.
Apparently the best I can hope for now from BT is Ultrafast via GFast but given Sky have now offered it as well for less than BT’s price it looks like I’ll be sticking with them.
