badbuy
Newbie
Message 1 of 3
New Home Hub
I purchased a new HomeHub 5 through amazon. Set up was easy and all worked fine, 3 days later the internet is down and no phone tone. I have reset and called bT but no joy so far?
2 REPLIES 2
Message 2 of 3
Re: New Home Hub
Unplug the home hub and then try your home phone to see if it works in the test socket. If not, then report it as a phone fault, as its probably a line fault.
Once the phone is working again, the Internet connection should restore.
Message 3 of 3
Re: New Home Hub
Hi badbuy,
Welcome to the BT Care Community Forums.
Is the Hub connected to the test socket via a microfilter or via a SSFP?
As Keith has said, connect just the landline phone to the test socket, the line should be quiet.
