lbspeller
Newbie
Message 11 of 13
Re: New Home
@ray_dorset wrote:
Which speed test?
Try another one. This for example http://www.thinkbroadband.com/speedtest.html
This is the result from the test you recomended:
Message 12 of 13
Re: New Home
As Ray has said, your stats look good. Do you have another device you could use. It may be a problem with your PC network card needing the drivers updated or the Ethernet cable faulty.
EDIT: Just noticed your edit!
Distinguished Guru
Message 13 of 13
Re: New Home
Can I suggest you try a factory reset?
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
If not, I'll try again 🙂
Tags (1)
