Message 1 of 14
New Huawei ONT
New Huawei ONT is now out. Anyone getting FTTP Installed anytime soon may end up with one.
13 REPLIES 13
Message 2 of 14
Re: New Huawei ONT
I’ve had mine for a few months now. Why have you got a bit of paper on it?
Message 3 of 14
Re: New Huawei ONT
These are the new Huawei ones, which has only just been released. They look like the Nokia ONT, which is most likely what you have.
And the piece of paper is to cover the ONT Serial Number. Leave that in the picture and I might as well just print my full name.
Message 4 of 14
Re: New Huawei ONT
  • Definitely Huawei
Message 5 of 14
Re: New Huawei ONT
And it’s quite small, only 134x115x25mm
Message 6 of 14
Re: New Huawei ONT
Yes that is a Huawei one, the old one. My picture is of the new one. Hence why I said, ‘the new Huawei ONT’.
Notice mine doesn’t have a TELE1 Port?
Message 7 of 14
Re: New Huawei ONT
Yes I was wondering why you didn’t have the TELE1 Port and the associated LED. How will you get VOIP if available?
Message 8 of 14
Re: New Huawei ONT
Tele1 was a proprietary system FVA (Fibre Voice Access) rather than a universal VOIP option which doesn't require a phone port on the ONT. FVA has been discontinued and replaced with Digital Voice which is supplied as a DECT signal from the SH2.
Message 9 of 14
Re: New Huawei ONT
Very neat little unit with no trims.
I like it.😎
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 10 of 14
Re: New Huawei ONT
What he said, FVA and VOiP are different services.
FVA is, or was an Openreach Product they have now stopped taking new orders for and are getting rid of it and it’ll be up to CP’s to Provide VOiP.
