DuWolfy
Message 11 of 11
Re: New Infinity 2 line slower than previous supplier
#Update
Even though I had recieved 65Mb when first installed the amount of people using the same service has reduce it down to 30-35Mb ( Speed test max @ 25-28Mb)
Engineer checked the Lines/Socket ... even went up the Pole to replace a connector on there which increased the speed slightly. Other than that there is nothing much he can do.
Guess I'm going to have to lower the package or look for a lower package from another supplier if cheaper.
Thanks for the help
