JonathanAnsell
Message 1 of 19
New Install
So I had BT Infinity activated yesterday. I was given a speed range of 35-53 Mbps and a minimum of 32Mbps.
The BT site now states if I ordered today I should get 40-57 Mbps and a minimum of 35 Mbps.
The DSL checker and technical log from the SH6 will follow.
I haven't tested using the test socket yet or tried a quiet line test but the DSL checker seems to think I can achieve far greater on a clean line than I am now. Is there anything that can be done or is it a case of wait and see?
18 REPLIES 18
JonathanAnsell
Message 2 of 19
Re: New Install
The low uptime is because the router is an FTTP SH6 connected to an Openreach modem. I had to disconnect it and move it to use the DSL port and get the stats.
Message 3 of 19
Re: New Install
from stats you have 41mb connection speed so within the estimate give by BT but lower than estimated speed from checker
I would try test socket with filter to see if that improves conenction by eliminating your internal wiring
Sage
Sage
Message 4 of 19
Re: New Install
Purely as matter if interset, why an FTTP HH6?
JonathanAnsell
Message 5 of 19
Re: New Install
The router sits on top of a bookcase so I thought the best way would be an Openreach modem to a router.
The other half doesn’t like to see the router and the Hub 6 is the smallest router I can get that still supports AC and I can easily hide.
All the super powerful awesome routers I’d happily buy are too big and I like the quiet life.
Sage
Sage
Message 6 of 19
Re: New Install
Understandable and I don't blame you.Smiley LOL
JonathanAnsell
Message 7 of 19
Re: New Install
So I tried the test socket with a new filter and cable. The line attenuation drops slightly, the noise margin drops by a third, the max data rate drops massively, and the data rate drops slightly.
A quiet line test alebit with a cordless phone doesn't have any noise. I'll try with a corded one and double check at some point.
A speed test on the BT wholesale site is attached also.
shamus1
Expert
Message 8 of 19
Re: New Install
where are you located just curious?
JonathanAnsell
Message 9 of 19
Re: New Install
The not so sunny seaside town of Scarborough.
shamus1
Expert
Message 10 of 19
Re: New Install
ok thanks,why not just try hub 6 on its own to see if stats any better?
